Originally Posted by Insight for life
You can force charge the battery by revving over 3000 in neutral. Anything under 19 bars out of 20 and the battery will background charge(not seen) . Your best bet is to install a calpod/clutch switch to keep the battery from assisting and or background charging
Wait so what I understand from the calpod, could I wire a switch I had (toggleable, kinda like a light switch) to just run it through that, then into the calpod again? I'm really confused on how to do this properly and google turned up no results on how to properly install one.
