No, he's correct. It may sound counter intuitive but the apex is later in the corner if you want to hit the gas sooner.
The apex is where you hit the inner limits of the track. That is not the point where the radius is smallest, unless you do a neutral corner. If you get on the gas early, or late, the point of smallest radius moves one way and the apex moves the other way.
You've seen that link 2000mc provided? That should make it clear.
Originally Posted by that link:
It's very common for drivers to apex too early due to nerves about the approaching corner and eagerness to take the turn. The racing line apex which is often out of view at the point of turn in, or further round the corner than you expect
