Good question on the ground clearance. I was going to build it with 5", and so have about 4" loaded? My car will have no overhang front or back and that helps a little on the clearance issue. To build my frame I was going to do the floor panel flat on the garage floor. The sides would be roughed out on the garage floor separately, and then just stand them upright on the floor panel and welded on? Then add the roof? Yes this light a frame shouldn't be that hard to move around.
Good luck!
Mark.
