Old 09-07-2014, 03:53 AM   #6880 (permalink)
duncan
Back again
Hi Paul,
I'm back - not completely right but I've managed to get some decorating done so I'm allowed to look at my car
Some damage in transit
Nothing serious
I have plugged in what I can,
So there is the IBGT's and their monster capacitor,
And a control board
What is the other board for???
(the one that came completely loose in transit)
I need to make some end bits to support the cables, that will support the current sensors
Then I need to identify the wires on the other two boards
I have included pictures of the Puma my brother made,
I've no idea what I'm going to do with it
I found some water cooling plates on Hobbyking
https://www.hobbyking.com/hobbyking/...dProduct=21192
They are $16/pair
I intend using one under each IGBT
I'm thinking of using a windscreen washer bottle with a built in pump and returning the water via a small cooler under one wing (fender?)
ID:	15752   Click image for larger version
ID:	15753   Click image for larger version
ID:	15754   Click image for larger version
ID:	15755   Click image for larger version
ID:	15757   Click image for larger version
ID:	15758   Click image for larger version
ID:	15759   Click image for larger version
ID:	15760   Click image for larger version
The Following 2 Users Say Thank You to duncan For This Useful Post:
jedsmd (09-07-2014), MPaulHolmes (09-15-2014)
