Old 09-07-2014, 04:02 AM   #3 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by H-Man View Post
My car has the VSS signal go through the cluster to the ECU, as such I'm going to make it so that I can switch the VSS to the ECU off when I'm coasting in neutral so that I don't fast idle.
The insights dash is fully electronical. It's ribbon cables and PCB's my first thought was to cut the vss signal to the ECU, so the car would think it's not moving, and activating auto-stop. Not sure if it would work though.
