The charge voltage (battery voltage) was one one of the alarms that was factory set which kept triggering an alarm on my Ugauge nothing to do with the problem you are having.
If you have gone back make sure you turned on the individual alarms under max setting. and it took.
There should get two type of alarms one visual believe it flashes on the display, the second is a tone. If you do not get either check this setting.
All alarms on/off
MENU > Alarms .. > All Alarms on/off
Globally enables or disables all Gauge Alarms both audible and visual.
If you get the flashing message and no sound check this.
Alarm siren on/off
MENU > Alarms .. > Alarm siren on/off
Allows the audible alarm siren to be switched on or off. This only affects the audible siren and does not affect the visual siren.
If both of these are enabled or on and the max setting is programmed correctly and set to on it should work.
That's all I got.
