Originally Posted by vskid3
InsightCentral is definitely the best place to research/ask this question. I believe there's a few ways to do it on the Insight.
Yea and the method (easiest) I want to use, the only member who used to never made a DIY on how to do it. He gives a general description but doesn't specify why there wire is that I need to tap into.
Do you happen to know where the power supply wire is that feeds all the injectors with power?
