Old 09-07-2014, 12:35 PM   #8 (permalink)
Cobb
Maybe you need to flip it over or maybe it was providing way more support than you are giving it credit and once it was unloaded the pieces moved?
The front skid plate to my sidekick is a real ***** and a half to reinstall. I have to install all 3 bolts finger tight, then use a power wrench to run the 4th one in at an angle. Then I snug up the other 3 and finally the last one. YOu can see from the fan its flexed, but Im not able to bend the frame to make it fit right.
