Old 09-07-2014, 05:06 PM   #6 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by nemo View Post
There should get two type of alarms one visual believe it flashes on the display, the second is a tone. If you do not get either check this setting.
All alarms on/off
MENU > Alarms .. > All Alarms on/off
Globally enables or disables all Gauge Alarms both audible and visual.
Thanks much for your message. This is the one that did it. I thought it meant to turn all the alarms on, but it simply means to enable the alarms to be set individually. During my test, the max value needed to be exceeded for a couple of seconds to be triggered. Even so, the alarm is a nice and helpful feature to have.
The Following User Says Thank You to j12piprius For This Useful Post:
nemo (09-07-2014)
