Originally Posted by 101Volts
60 MPG In-City? That's an achievement. Do you have engine heaters?
Nope.
Originally Posted by kafer65
Very cool that's with ac running too, I presume based on 100f temp? Is the ac separately running with engine auto shutdown at stops w the Insight?
Nope, no A/C. The car has A/C but it's out of freeon. And the way the insight works, if you have the A/C set to "Econ mode" it will turn off the engine (and the ac with it) at stop lights when it enabled auto stop.
Originally Posted by mcrews
Get the alignment sooner rather than later.....
chewed up my front tires on the Q45.
Yes, I will be doing it this coming Friday for sure.
Originally Posted by Old Mechanic
You can set the toe with a tape measure. At least that would get you close.
regards
mech
How?
Also guys, I learned my UG is reading 5mpg lower then what I'm actually getting. So I actually got 66 I suppose instead of 61 on that trip.
