Hi,
Have you tried to disconnect that sensor while engine is running? That should be your first step. If that will work and after connecting sensor you can start your engine without ECU throwing an error then you can go to the next stage.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
