Originally Posted by MetroMPG
That's a good thing! If you have the time, and won't be annoying following drivers (who can't pass you), then start the neutral coast sooner. That'll save more fuel.
If you are *trying* to slow down faster than coasting in N, then using deceleration fuel cut-off in gear is more efficient than using the brakes. But coasting in N is generally more efficient than DFCO because you get off the accelerator (accel. or maintaining speed, burning the most gas) even sooner.
Also, your car only cuts fuel above a certain RPM, and possibly not at all in the lowest gears (your gauge may show you this). I recently drove a brand new Nissan 4-speed automatic that never cut fuel in 1st or 2nd gear.
I only know of one person who has worn out a starter while trying to save fuel, but he was shutting off at every single opportunity, including pulse & glide (automatic). Driving a Honda.
Stopping the engine when the car is stopped is worth roughly 5-10% better fuel economy in city driving, which is why auto stop/start is now becoming common on new cars (including non-hybrids).
Whether you should do it or not is entirely up to you.
I'm so glad to hear this. Finally, I don't feel insane or fretting anymore
