Old 09-09-2014, 12:18 AM   #25 (permalink)
serialk11r
Diesel engines run WOT all the time.
Touche
But this is more about excess pressure at blowdown, which for a diesel still corresponds to load. At lower loads a turbo-generator will not be efficient at all on a diesel engine and the restriction it introduces could negate a lot of the benefit. That said the setup that they use in Formula 1 where the turbine is very free-flowing and uses the electric motor to augment boost would probably work very well on a diesel street car, albeit very expensive.
