Old 09-09-2014, 11:38 AM   #106 (permalink)
Fat Charlie
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I'm going that way too, thanks to Jedi Sol's excellent explanation of his own work. This is what I have lined up for mine:
A normally closed, momentary open pushbutton switch
A relay and socket
Some connectors
A "Fuse Buddy"
Basically, just looking at the add-a-circuit makes me think "I see how I can get power from it, but how do I open and cloer the circuit with just the one wire?" The Fuse Buddy made more sense to me- one wire on one side and one wire on the other. I cut the leads off and I'm just waiting for some time to solder everything together and drill a discretely placed hole to mount the button.
I did test it- I put the Fuse Buddy in the injector fuse slot, held the wires together and started up. After I got rolling I separated the wires, then put them back together, bump started and parked the car. And promptly haven't had any time to put it together properly.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
PaleMelanesian (09-10-2014)
