Old 09-09-2014, 04:29 PM   #226 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by The donkey CRX View Post
Hi John, Both the front air gaps and the rear fender skirts were attached by cutting 1" by 1" 90 degree angle aluminum into 1 1/2" lengths and using #6 X 1/2" stainless screws to attach it to the lip of the fenders.
Thank you very much for the details!
Then I attached a 6-32 stainless bolt with a 6-32 nylock nut to the angled aluminum. the angle was recessed back into the fender lip enough to move the nut back so when the air gap or rear fender skirt was installed with another nylock nut on the outside it would be flush with the fender.
Do you mean like this?
bolt on inside > aluminum fastener > nylock nut in middle > aluminum skirt > nut on outside
Why not have a more aerodynamic screw head on the outside, or do you feel there's not much difference aero wise, and having the nut there makes removal much easier? How often do you remove the skirt for checking your tires?
Also, what did you use for the side skirts, and how high are they from the ground, 5 inches?
Best regards.
