Old 09-09-2014, 11:19 PM   #1 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
how does the MAP readout work?
I've been using % engine load, and tried MAP today for comparison. According to the Ultragauge manual, MAP goes up to 255 kPa (kilopascals). Based on that, I figured 90% engine load would be about 230 kPa, but that isn't the case.
When % engine load got up to 90%, the kPa's were only approaching 100!
Interestingly, standard atmospheric pressure on Earth is defined as 101.325 kPa.
Does MAP have a direct relation to fuel use, i.e. up to 100 is efficient, and above 100 is excessive? Therefore 101 to 255 MAP is relative to 93 to 100% engine load?
If so, I think that's quite neat.
