Old 09-10-2014, 03:59 PM   #40 (permalink)
SilverCrown9701
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
You describe having DFCO while in neutral, which does not sound possible. I am not doubting you regarding the 0.6 GPH in idle, but my Forester only uses 0.25.
It really depends on what you are doing. If you are a light-timing genius, you should never need to coast in-gear or use your brakes, while DCFO uses no gas and neutral uses a little, how much do you use accelerating back up to speed?
If you have a stop sign, would you prefer to drive at your city mileage and then DFCO, or coast in neutral for a much longer distance? That is, unless you have people behind you. I always do, all hours of day and night.
If you have a very gradual hill and you can roughly maintain your speed in neutral, that makes more sense than keeping it in drive and getting 40-45 MPG, because you could get 91.67 at 55 MPH.
If you have a steeper hill, you need to stay in-gear for engine braking, and sometimes you need to downshift.
My ex-girlfriend complained that the transmission was rough shifting between neutral and drive and then she replaced her transmission mounts. She is my ex-girlfriend, I try to avoid her and definitely not to help her think through her problems anymore, but I did try to explain that some repairs are not worth the money, and how terrible an idea it is to pay for things when it puts your account in overdraft.
No, I never said I had DFCO while in Neutral. It's only in Drive.
My apologies, I meant to type .25 GPH, not .35 GPH...(I'm using a mobile phone to type so my fingers keep missing the correct buttons.)
Whether I use Neutral or Drive to slow down to stop, I will still have to get back up to speed, so I am at a slight loss either way.
I guess I will need to try one tank on neutral coasting alone and another on DFCO. I just really don't want to risk having to replace my transmission for $3,000+...
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
