Old 09-10-2014, 09:21 PM   #1 (permalink)
snydertalon
Help with bellypan
Yes I've searched....
I'm looking to make a fiberglass belly pan. I know coroplast would be a bit cheaper, but I want to learn how to make things with fiberglass. I figure something I will never see would be perfect.
Things I'm sure about:
It should be flat.
Put aluminum near the exhaust.
It will be in panels running the width of the car for easy removal.
Things I'm not sure about:
Will I need rear diffusers? The profile of my car doesn't seem like there is a big angle change exiting the rear of the car (http://4.bp.blogspot.com/__nK5eqVEjq...2041990004.jpg)
Looking at the profile of my car, I have 'mud flaps' in front of the tires, which some people seem to add to their belly pans. The problem is I've seen some perpendicular, some angle in, and some angle out. Not sure which is the winner. Hell, should I add a boat front (if a boat tail is on the rear a boat front is in front of) the wheels to make the entry easier?
Since I'll be working with fiberglass, basically any shape is obtainable.
