Old 09-10-2014, 11:27 PM   #17 (permalink)
user removed
Originally Posted by Baltothewolf View Post
Heater works awesome. And Yea the top hose is hot as well as the bottom hose.
Top and bottom hose both hot= radiator not removing enough heat due to restricted cooling passageways in the radiator. The misalignment show in your photo will not cause the overheating your describe.
Also any time you open up the cooling system there is a very specific bleeding procedure.
regards
mech
Baltothewolf (09-21-2014)
