Originally Posted by Old Mechanic
Top and bottom hose both hot= radiator not removing enough heat due to restricted cooling passageways in the radiator. The misalignment show in your photo will not cause the overheating your describe.
Also any time you open up the cooling system there is a very specific bleeding procedure.
regards
mech
Yea I followed that procedure to the T. I just burped the system again and a ton of air bubbles came rushing up the second I turned the car on. I think I'll just replace the radiator to rule that out.
