Originally Posted by Baltothewolf
Ok that's what I figured. I'm at work right now, so I'll check it when I get home and do as you said exactly.
Check the recovery bottle when you leave work. You could carry a small container of coolant to top off the radiator and recovery bottle. Of course, in those hot temperatures I would not run the heater
Bleed when you get home, then let it cool and top off again. Never run it with the cap off unless you are checking for proper thermostat operation and opening temperature, which you have already done when you replaced the thermostat.
regards
mech
