Old 09-11-2014, 10:28 AM   #38 (permalink)
user removed
You do not need to remove anything to check the recovery bottle or to bleed the system, except to open the bleeder. Only open things when the engine is cold or you could get burned badly by scalding hot water, a real danger when you have a big air pocket that gets super hot then gets hit with colder water and you have a geyser of scalding water blowing out of the radiator and all over you.
YOU WILL ONLY DO THAT ONCE!
I have'nt
regards
mech
Baltothewolf (09-21-2014)
