Pressure on inyectors
Hello TheTestPilot,
Tks for coming. Well, the injectors are not common rail. The engine uses indirect injection. Each injector has over 20:1 of pressure I asume, as they must defeat compression in the cylinder.
I recall I have a compression test to the engine, I can search it if you want.
What are you thinking about?
Looking forward to hear about you and yr thoughts,
Oldbeaver
Mercedes 300 D turbo 1993
