Old 09-11-2014, 11:23 AM   #39 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Old Mechanic View Post
You do not need to remove anything to check the recovery bottle or to bleed the system, except to open the bleeder. Only open things when the engine is cold or you could get burned badly by scalding hot water, a real danger when you have a big air pocket that gets super hot then gets hit with colder water and you have a geyser of scalding water blowing out of the radiator and all over you.
YOU WILL ONLY DO THAT ONCE!
I have'nt
regards
mech
So I just got home from work, and before bleeding I thought I would feel the radiator hoses. I touched the bottom one and I could grab it and hold it with my hand forever if I wanted to, it was barely luke warm. I touched the top one and had to apply ice to my hand, and it still hurts. My dad, who has tough as hell hands, couldn't even touch it for more then 1/4 of a second. What does this mean?
Forgot to add, car did not overheat on way home from work.
