Originally Posted by RedDevil
If you jack the car one wheel at a time you should pull the handbrake, the rears will be hard to spin then
No, you don't apply the handbrake. Obviously, if you apply the parking brake the rear wheels won't turn. To check the rear wheels on a FWD vehicle, leave the transmission in park. They should turn freely. They are not attached to the drive train on a 2 wheel drive car that has FWD.
I had my car lifted in N and no park brake on. Rear hubs could be spun with a finger. Front hubs were hard to rotate without the wheel for extra leverage, just because of the drive shaft and stuff.
No, if the transmission is in neutral the wheels should turn easily.
We opened up the brake calipers to add brake pad return springs (from the OEM single one on the leading edge of the pad to a pair) but even with the pads visibly detached the front hubs were hard to spin.
I found my brake pads would stick occasionally.
That could be it. But there should be no rolling resistance when in neutral.
