Originally Posted by SilverCrown9701
I would kill for a vehicle lift. Sadly, I only have jack stands
If you review my past posts you will find that I mentioned that you only jack up one wheel at a time to check it. You only need an ordinary jack to do that. You don't even need to remove the wheel. Once the wheel is off the ground it should turn easily.
