Originally Posted by e*clipse
Check out the Tamagawa app note for a more in-depth explanation of the situation. This is what actually needs to be done for an automotive environment....
No worries, just thought i would mention it in case an easier solution was being overlooked.
I can understand the noise issue. It was something that was high on my list of reasons for using an encoder back when Paul asked for opinions on resolver versus encoder.
Its a pity that you can't just swap out the resolver for an encoder. Maybe an encoder bearing?
But when you get it working it will be a real neat solution. Bolt the MGR to the chassis, connect the half shafts, connect a few cables and away you go. No adaptor plates or input shaft couplers. And at the cost you could have a spare on the shelf ready for a quick swap over if the current one developed issues.
