Old 09-12-2014, 02:42 PM   #1 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Active grill shutters at the dollar store!
These vents have a pair of plastic shutters that are actuated by a small DC motor. Perfect for an automated grill block! But being a motor, they need only a short electrical pulse to move. You can't feed them continuous power. The timer takes 2 AAA batteries, so I assume the motor gets about 3 volts. It works fine on 1.2v. I wouldn't try 12v! Some weatherproofing for the motor will be necessary. The shutter area is about 4" x 9". I'll try one first, maybe that'll be enough airflow. I usually have a smaller grill opening than that.
I bought a bunch. I'll make a post in the classifieds if anybody else wants to play with one. Or if you're in Upstate NY, look for Real Deals Dollar Stores!
ID:	15799   Click image for larger version
ID:	15800   Click image for larger version
ID:	15801   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 17 Users Say Thank You to Gasoline Fumes For This Useful Post:
aerohead (03-31-2015), BamZipPow (09-15-2014), Cd (09-13-2014), CigaR007 (03-30-2015), Daox (09-12-2014), fusion210 (09-13-2014), gumby79 (06-30-2015), jeff88 (09-12-2014), mcrews (09-12-2014), MetroMPG (10-02-2014), ME_Andy (09-12-2014), mikeyjd (09-13-2014), mpg_numbers_guy (03-15-2018), Occasionally6 (09-12-2014), shankar_roy (11-24-2015), SwamiSalami (10-16-2014), UltArc (09-14-2014)
