Old 09-12-2014, 05:51 PM   #65 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by Old Mechanic View Post
In a perfect world, if you spend the money, they fill them with slight pressure and a hose hooked to the bleeder that collects the overflow for future use.
Obviously if the cost of the radiator is an issue then an expensive piece of equipment to do a job once, makes little sense and I referenced a previous experience when I had to go back to the shop to get my Riviera bled again.
It takes little effort to break the bleeder loose a few times to confirm the system has no air pocket, I call that good insurance and once done then you can just monitor the recovery bottle for any change the would indicate loss of coolant.
regards
Mech
Well you were right, just as I suspected. There is major, major cold spots on the radiator (up to a 40° difference). I went to get the radiator but they didn't have it, and won't have it until Monday. Which is ok.
