Originally Posted by Chrysler kid
Also for reference if you are lucky enough to still have the factory radio you will retain your keyless entry. The factory radio contains the rf signal receiver for the keyless entry
So if I go and buy a used factory Civic CD deck (which I want to do), isn't there some sort of code derived from the car's VIN of the deck's donor car that I need to make it work? Is there a way around it? Can I then get any old keyless remote and somehow program it to work?
