Old 09-13-2014, 04:15 AM   #12 (permalink)
AusKiwi
Originally Posted by Tesla View Post
I use a little (0.5%) mineral 2-stroke oil for extra fuel lube as well as a diesel fuel additive to keep lines clean, have not noticed difference in fuel economy, although bottle states "may improve FE".
I think the additive can help with bad fuel or if system is a bit blocked, but if system and fuel is good then additive is more of an insurance type thing.
I too have experimented with two stroke and also with Morey's diesel additive which is a similar oily consistency like the two stroke. Like you, didn't see a huge difference. More recently, I have been testing the Pro-Ma DT5 diesel additive which is more like the consistency of petrol, and contains a fuel system cleaner as well as a surfactant which breaks down any water in the fuel and a combustion modifier to make the fuel burn more completely. Long story short, the engine seems to have more power and I am getting as good as 5.7 litres per 100kms from my Citroen C5 2.0 HDi whereas before it was averaging between 6.5 and 7. I now use a combination of the three additives while I use up the Morey's but probably won't buy that again as the Pro-Ma product seems to make the biggest difference and if I want to boost lubricity a little more, the two stroke is way cheaper than the Morey's product. I joined up as a distributor to get the Pro-Ma DT5 cheaper so can get a litre of that for about $23 which works out about 2.3 cents per litre of fuel treated. I figure I am saving about 15 cents a litre at current fuel prices so I come out ahead, but even at full retail price it would still only cost 3.6 cents per litre of fuel treated so worth it for anyone to try.
Save fuel by treating it - costs 5c/litre, save 15c, it's a no-brainer. Message me for more information.
