Old 09-13-2014, 09:41 PM   #26 (permalink)
BobS
diesel doer
bigscoot
I agree with 2000mc on the particulars. I would add to his first statement that diesels, to take the pressure of the instantaneous combustion, are made massive - thus more mass leading to lower rpms. I also would like some limit on the air/fuel mix - optimum ratio just at lower pressure at the intake. And we offer two solutions to your quest.
He suggests multiple injections which I believe is very much a workable solution. I, however, believe that you can use a vaporizer (perhaps ultrasonic with a heater) to modify the characteristics of the diesel fuel to allow it to burn in an otherwise unconverted gas engine. I suggest this since you seem to be time bound and this is the most rapid answer to your project need.
The Following User Says Thank You to BobS For This Useful Post:
Xist (09-13-2014)
