Old 09-14-2014, 02:39 AM   #1 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Increasing frontal area and reducing drag
I have been kicking around my travel trailer design for years now, and like all things it has gone through several changes. it is a good thing I have not started construction yet!!
Here are the nuts and bolts of the latest changes.
before, I was committed to the lowest possible frontal area while keeping certain interior size goals.
This meant compromises in the shape, compromises that would not produce the lowest possible CD.
Now I see the folly in that approach.
If I increase the area from 60 to 64, for example, it means a change of around 7%.
If the new shape, (which still meets the interior size goals ), improves the CD from .30 to .27 I have made an overall improvement in CDa.
If it goes from .30 to .23 I have made some serious improvement.
Basically the more I can do to match up with the template the more I can gain, regardless of increase in frontal area.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following User Says Thank You to skyking For This Useful Post:
Hersbird (09-15-2014)
