Old 09-14-2014, 06:32 PM   #2 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
On my prizm, it took a power output of ~43hp in 100F air doing 70 MPH up a 5% grade with the AC on, the upper grill blocked, and the car loaded down to 3200 lbs to exceed the thermal capacity of the radiator. To make 100 HP hours of mechanical energy, you have to put in almost 400 hp/h of fuel on most engines.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
