Old 09-14-2014, 07:37 PM   #9 (permalink)
user removed
Never consider learning about something as anything more than improving your knowldege base. I spent two weeks when I first started learning that plug wires could go bad. Also couldn't afford to buy a battery and just stuck the battery cables together and turned every bulb into a flash bulb with the 20 volt surge in power. Also tookalot of time buying USED bulbs from a junkyard.
regards
mech
