Old 09-14-2014, 09:32 PM   #3 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 44.87 mpg (US)
A good rule of thumb is that 1/3 of fuel burned goes to turn the crankshaft, 1/3 as heat to the radiator, and 1/3 as heat out the exhaust. This would apply to an automobile engine running near its best efficiency point.
Sample calculation:
Assume your engine burns 10 GPH at WOT.
Assume gasoline is 120,000 BTU per gallon. That sounds about right, I'm too lazy to look it up.
Then heat to radiator is 1/3 X 10 X 120,000 = 400,000 BTUH.
A large diesel engine can convert as much as 50% of the fuel into power.
