Old 09-14-2014, 10:26 PM   #242 (permalink)
The donkey CRX
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Xist, We are using the alloy space saver Insight 4"X14" rim with RE92 tires. The only difference I can see between the space saver rim and the Insight regular rims is the regular is 5 1/2" wide. I think the 50 MPH limit warning is because of the spare donut tire, not the rim.
I have put over 12,000 miles on a set of the 4" wide space saver rims and RE92 tire and have had no issues. I have not noticed any difference in braking ability, but as you say, we are not doing any heavy braking anyway.
I have seen 1 1/2 to 2 MPG gain using this combo compared to the same tire running on the 5 1/2" wide Insight rim (60 lb of air in each) The tire is noticeably narrower
And of course I am using the 4"space saver on all 4 corners of the car.
The 4" wide wheel is about 1 1/2 lbs lighter than the 5 1/2"
The Following 3 Users Say Thank You to The donkey CRX For This Useful Post:
mikeyjd (01-07-2015), OG VX (12-15-2014), Xist (09-14-2014)
