Old 07-16-2008, 01:40 PM   #5 (permalink)
Tango Charlie
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Originally Posted by lunarhighway View Post
@groar
be carefull not to turn the key all the way back because your breaklights and other things might not work anymore, and brakes pressure will disapear when you use the brakes more than 2 or 3 times so restart the engine if you need to do that.
so try it on a safe road without traffic.
That's not quite accurate. You will always have brake lights, even with the key out of the ignition.
-Terry
