Old 09-15-2014, 02:54 PM   #8 (permalink)
RedDevil
90 day: 55.4 mpg (US)
Running the A/C for short bursts at a time may not be good for at least some types of A/C.
Used to do this in my Almera and it started to leak. Might be unrelated, but I gave up on it. I believe the manual warned against using it for very short periods and shortly before leaving the car.
(My Insight manual does not or I could not find it).
My mobile A/C unit at home prohibits being shut off straight; it keeps the fan spinning for an additional 3 minutes unless you pull the plug, which you shouldn't. Then I wouldn't know if that was to protect it mechanically or prevent it from molding over. But I wouldn't want either.
Never hurts to look it up in your manual.
