Old 09-15-2014, 09:50 PM   #79 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Oh the radiator was definitely part of the problem, I had my little bro cover up the upper radiator hose thingy and I put a hose in the top so water had to go out the bottom hose (this was with the radiator out) and water flow was really low when comparing it to the new one.
The fans come on at 206 I already tested it multiple times.
I have a ton of coolant laying around so I'm gonna bleed again here in a little bit. If that doesn't work I'm gonna pull the water pump off and inspect it.
