fuel conserver
Civic - '99 Honda Civic EX
1992-1995 Honda Civic Specifications
1992-1995
Engine
Type
Aluminum Block and Head
Valvetrain
Sohc 4 valve/cyl.
Displacement
97 cu in./1590cc (EX, Si)
91.1 cu in/1493cc (DX, LX, VX, CX)
Bore x Stroke
2.95 x 3.54 in./75.0 x 90.0 mm (EX, Si)
2.95 x 3.33 in./75.0 x 84.5 mm (DX, LX, VX, CX)
Compression Ratio
9.2:1 (EX, Si, DX, LX)
9.3:1 (VX)
9.1:1 (CX)
Horsepower (SAE)
125 bhp @ 6600 rpm (EX, Si)
102 bhp @ 5900 rpm (DX, LX)
92 bhp @ 5500 rpm (VX)
70 bhp @ 5000 rpm (CX)
Bhp/Liter
78.1 (EX, Si)
68.0 (DX, LX)
61.3 (VX)
46.7 (CX)
Torque
106 lb-ft @ 5200 rpm (EX, Si)
98 lb-ft @ 5000 rpm (DX, LX)
97 lb-ft @ 4500 rpm (VX)
91 lb-ft @ 2000 rpm (CX)
Maximum engine speed
7200 rpm (EX, Si)
Fuel injection
Elect. sequential port
Fuel
Unleaded, 87 pump oct.
Chassis & Body
Layout
Front engine/front wheel drive
Body/Frame
Unit Steel
Gross Vehicle Weight Rating
Coupe
DX M/T: 3,245 lbs
DX A/T: 3,315 lbs
EX: 3,490 lbs (Including EX option package)
Hatchback
CX, VX: 3,055 lbs
DX M/T: 3,090 lbs
DX A/T: 3,210 lbs
Si: 3,270 lbs
Si w/ ABS: 3,305 lbs
Sedan
DX M/T, LX M/T: 3,245 lbs
LX M/T w/ ABS: 3,405 lbs
DX A/T, LX A/T: 3,315 lbs
LX A/T w/ ABS: 3,405 lbs
EX: 3,490 lbs
Brakes
Front
10.3 in vented disc
Rear
9.4 in disc w/ABS (EX Sedan, Si Hatchback, EXa Coupe, Available on LX)
7.9 in drums (DX, LX)
7.1 in drums (VX, CX)
Assist type
vacuum
Wheels
Pressed steel, 14 x 5J (EX, Si)
Pressed steel, 13 x 5 (DX, LX, CX)
Alloy, 13 x 4.5 (VX)
Tires
P185/60R-14 82H (EX Coupe, Si)
P175/65R-14 (EX Sedan)
P175/70R-13 (DX)
P165/70R-13 (VX, CX)
Steering
Rack & Pinion
Power Assist (EX, Si, LX, DX Sedan, DX Coupe w/ Auto transmission) Manual (DX Coupe w/Manual transmission)
Overall ratio
17.5:1 (Power)
19.0:1 (Manual)
Turns, lock to lock
3.58 (Power)
3.88 (Manual)
Suspension
Front
Upper A-arms, lower L-arms, coil springs, tube shocks
21.0 mm anti-roll bar (EX, Si, LX)
Rear
Trailing arms on upper & lower lateral links, compensating links, coil springs, tube shocks
13.0 mm anti-roll bar (EX Sedan)
Acceleration (EX)
0-30 mph
2.9 secs
0-40 mph
4.6 secs
0-50 mph
6.5 secs
0-60 mph
9.1 secs
0-70 mph
12.1 secs
0-80 mph
15.5 secs
0-90 mph
21.8 secs
0-100 ft
3.4 secs
0-200 ft
9.1 secs
0-1320 ft (1/4 mile)
16.8 secs @ 82.3 mph
Standard Equipment, Civic Sedans
DX Sedan includes:
Dual Airbags (SRS), 1.5 Liter, 102-hp, 16-Valve Engine with Programmed Fuel Injection (PGM-FI), Power Steering, 4-Wheel Double Wishbone Suspension, 5-Speed Manual or 4-Speed Automatic Transmission, P175/70 R13 All Season Tires, Coin Box, Beverage Holder, Fold-Down Rear Seatback with Lock, Adjustable Front Seat Belt Anchors, Dual Manual Remote-Operated Mirrors
LX Sedan adds:
Power Windows, Mirrors and Door Locks, Cruise Control, Tachometer, Center Console Armrest with Storage Compartment, AM/FM High Power Stereo Cassette with 4 Speakers, Quartz Digital Clock, Cargo Area Light, Front Stabilizer Bar, 14" Wheels with Full Covers, P175/65 R14 All-Season Tires, Available Anti-Lock Braking System (ABS) with 4-Wheel Disc Brakes
EX Sedan adds:
1.6 Liter, 125-hp, 16-Valve VTEC Engine with Programmed Fuel Injection (PGM-FI), Anti-Lock Braking System (ABS), 4-Wheel Disc Brakes, Rear Stabilizer Bar, Air Conditioning, Power Moonroof
Standard Equipment, Civic Coupes
DX Coupe includes:
Dual Airbags (SRS), 1.5 Liter, 102-hp, 16-Valve Engine with Programmed Fuel Injection (PGM-FI), 5-Speed Manual or 4-Speed Automatic Transmission, Power Rack and Pinion Steering (AT only) Power-Assisted Front Disc/Rear Drum Brakes, P175/70 R13 All Season Tires, Beverage Holder, 2-Speed/Intermittent Windshield Wipers, Fold-Down Rear Seatback with Lock, Dual Manual Remote-Operated Mirrors
EX Coupe adds:
1.6 Liter, 125-hp, 16-Valve VTEC Engine with Programmed Fuel Injection (PGM-FI), Power Rack-and-Pinion Steering, Front Stabilizer Bar, 14" Wheels with Full Covers, P185/60 R14 82H All-Season Tires, Power Moonroof w/ Tilt Feature, Body-Colored Dual Power Mirrors, Power Windows and Door Locks, Cruise Control, AM/FM High-Power Stereo Cassette with 6 Speakers ('94 and '95 models only), Quartz Digital Clock, Available Anti-Lock Braking System (ABS) with 4-Wheel Disc Brakes
Standard Equipment, Civic Hatchbacks
All Civic Hatchbacks Include:
Dual Airbags (SRS), Multi-Point Programmed Fuel Injection (PGM-FI) Engine, 5-Speed Manual Transmission, 4-Wheel Double Wishbone Suspension, Beverage Holder, Split Fold-Down Rear Seatback, Coin Box, Two-Piece Hatch
CX Hatchback Key Features:
1.5 Liter, 70-hp, 8-Valve Engine, P165/70 R13 All-Season Tires, Rear Window Defroster with Timer, Hatch-Open Warning Light, Remote Fuel Filler Door Release, Remote Hatch Release, Passenger Assist Handle, Dual Manual Remote-Operated Mirrors
DX Hatchback Key Features:
1.5 Liter, 102-hp, 16-Valve Engine, Available 4-Speed Automatic Transmission with Power Steering, P175/70 R13 All-Season Tires, Adjustable Steering Column, Removable Cargo Area Cover, 2-Speed/Intermittent Windshield Wipers, Rear Window Wiper/Washer, Remote Fuel Filler Door Release, Remote Hatch Release, Dual Manual Remote-Operated Mirrors
VX Hatchback Key Features:
1.5 Liter, 92-hp, 16-Valve VTEC-E Engine, Lightweight 13" Alloy Wheels, P165/70 R13 All-Season Tires, Chin Spoiler, Tachometer, Dual Manual Remote-Operated Mirrors
Si Hatchback Key Features:
1.6 Liter, 125-hp, 16-Valve VTEC Engine, Power Steering, 4-Wheel Disc Brakes, 14" Wheels with Full Wheel Covers, P185/60 R14 All-Season Tires, Power Moonroof with Tilt Feature, AM/FM High-Power Stereo Cassette, Cruise Control, Rear Window Wiper/ Washer, Tachometer, Adjustable Steering Column, Removable Cargo Area Cover, 2-Speed/ Intermittent Windshield Wipers, Body-Colored Dual Power Mirrors
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
