So based on the above chart, would it make sense to keep track of these gauges on the UltraGauge to help increase fuel economy??
-Percent Engine Load
-Intake Manifold Absolute Pressure (MAP) PSI
-Ignition Timing Advance
-Intake Air Temperature (°F)
-Absolute Throttle Position Percentage
-Bank 1 Oxygen Sensor 2 Voltage
-Bank 1 Wide Oxygen Sensor 1 lambda Voltage
-Volumetric Efficiency
-Mass Air Flow 2, Calibrated/Calculated
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
