Balto, thanks for the heads up. My car currently gets into lean burn at 65 mph and 2400 rpm in 5th gear just as you mentioned and is fairly easy to maintain. Were you able to still engage LB in 4th gear with the CX transmission? I figured with the longer gearing, target LB rpm can still be obtained cruising in 4th gear instead of 5th gear?
Also, do you think could switching to 13" wheels might help hit the target rpm range in the higher gears?
