Thanks for the details and photo. It looks like they blocked the sides directly but left a big valley at the bottom. I see no reason for slats on the front of mine other than protection, as they block the airflow and prevent any ducting at that point. Is there any reason to not remove them? If not, I plan to cut them off and then put straight corplast from the opening to the edges of the radiator.
