My aim when accelerating is to stay as close to 90 % engine load as possible, without exceeding it, as above 93% is open loop which uses more fuel.
My plan for MAP is much the same. I'm using the metric MAP gauge which goes up to 100. See here for
The donkey CRX's comments about using a (non metric) vacuum gauge. You can choose either one. MAP is a digital vacuum gauge.
