Old 09-19-2014, 10:10 PM   #30 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by SilverCrown9701 View Post
From a physics standpoint, wouldn't accelerating at target load % for a designated time, which prolongs the downshift, consume more fuel versus accelerating enough to shift through each gear to get into overdrive?
Right. Overdrive is basically a downshift to generate more power at higher rpm's. A more detailed explanation is here.
In my automatic, that has no gauge, I use moderate throttle to get up to the highest gear as soon as possible (lowest mph), continue moderately accelerating in high gear (not overdrive), then shift into neutral and coast. The object is to keep the rpms as low as possible for the speed.
I would probably watch the instant mpg gauge carefully to see how to adjust.
The Following User Says Thank You to j12piprius For This Useful Post:
SilverCrown9701 (10-03-2014)
