Old 09-19-2014, 10:08 PM   #129 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
So I just got finished with my leak down test and now I'm even more confused! They all passed with flying colors! No abnormal hissing, no bubbles in the coolant, no air hissing from the oil fill cap, no hissing from the tailpipe! I even took the leak tester off and chucked it directly to my air compressor that had 100PSI of air and sure enough, no increase in hissing. I'm not convinced it's the head gasket... Something should have shown up!
I would also like to add I did them twice. I started with #1 and worked to #3 then did #1 again and repeated. Same results both times.
