Old 09-19-2014, 10:38 PM   #33 (permalink)
SilverCrown9701
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
Originally Posted by johnlvs2run View Post
When an automatic you have to toss load out the window, because it would cause a downshift. Rather, aim for higher gears and lower rpms.
I'm not sure what you mean by these. The idea is to not downshift at all, until you're reaching lower rpms that make this more feasible.
Based on not having used overdrive, I would avoid using it, unless someone else can explain that using it is efficient.
I tend to shift between 1500 and 2000 rpms, but go by feel, and don't pay much attention to the numbers.
The idea is to upshift as soon as possible, i.e. at lower rpms, with the caveat that I'm not familiar with overdrive gearing.
I've always used overdrive and it has provided the best return on fuel economy, the UltraGauge also supports this.
I'm sorry for the confusion. All I'd like to know is the most efficient way to accelerate for an automatic transmission to get into top gear as soon as possible at the least amount of fuel consumed.
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
