Old 09-20-2014, 04:41 AM   #13 (permalink)
Baltothewolf
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
I had a 1995 camry that I put an extremely good looking grill block on. I don't recall anyone ever noticing it unless I told them it was there. I took a hard plastic Mud flap. HARD PLASTIC, NOT THE HEAVY RUBBER KIND. And cut it with a electric saw blade type tool to fix exactly into my grill. I had to shave it with a file to get it to fit just right, and took me around 5 hours to get it done. It was well worth it in the long run. If you look through my old posts you will see an older version of it, before I took a file and made it fit absolutely perfect.
But I will warn you, grill blocks are by far the most dangerous of the eco-mods and not enough warning is emphasized. It's so easy to block to much and burn up your motor, or in the very least blow a head gasket. I can't voice enough that you must get an ultragauge and watch temps.
