Old 09-20-2014, 06:49 PM   #17 (permalink)
XYZ
Originally Posted by SilverCrown9701 View Post
Can anyone help me with a grill block? Something inconspicuous yet cheap and efficient. Any help is greatly appreciated!
It's easier to do a radiator block. There is often a small space (less than an inch) between the grille and the radiator. Cut a piece of ordinary cardboard to fit, that you will slide downward into that space. Leave enough of the cardboard panel protruding at the top so you can also pull it out to remove it. If there is a support in the middle, use two pieces, one for the left side and one for the right. The cardboard will stay there by itself in most cases. If the temperature gets too hot it's very easy to stop and remove it, as it takes only a few seconds to do.
Another nice feature is that it's disposable and costs nothing to make.
